12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> DIMENSION SETTINGS
9 Posts No Rating |
DOES ANYONE KNOW HOW TO ELIMINATE THE ZERO BEFORE AN INCHES DIMENSION. FOR EXAMPLE, IF YOU HAVE A DIMENSION OF 3-1/2" REVIT SHOWS IT AS 0' - 3-1/2" ON THE DIMENSION STRING. HOW DO YOU GET RID OF THAT? THANKS,
In your "Units Format" in your Dimension property put a check in the checkbox "Suppress 0 feet"
4 Posts No Rating |
Thanks, That helps. I was looking for the dimension precision as well, and it was in the same place.
Dimension line fixed distance from an Object |
Tue, Aug 22, 2017 at 8:18:26 AM
Having Dimension text in string, not above dimension string |
Fri, Sep 25, 2009 at 12:18:08 PM
Activate Dimension |
Tue, Dec 13, 2011 at 12:53:44 PM
Dimension Categories |
Mon, Oct 29, 2007 at 10:18:19 AM
modify dimension settings |
Wed, Oct 26, 2005 at 9:19:44 AM
