Forums >> Community >> Newbies >> profile in family
Tue, Jul 24, 2007 at 12:11:30 PM | profile in family
bobv
HiCreated a profile. Placed dimensions and created parameters.Created a family. Placed a sweep. Created a catalog. Attached the profile. Profile reads catalog but when I try to adjust parameters nothing happens. I know it is possible because if I open C-Channel.rfa I can adjust parameters. Spent all weekend trying to get it to work. Any help will be appreciated.bob v
Thu, Jul 26, 2007 at 11:20:06 AM | profile in family
kesflower
3.5 Stars: 11 Votes
When you change the parameters in the catalog types in the family itself and save it, then load it, are your changes still there, or do you get a "cannot create type" error?
 You may be missing a single parametered dimension somewhere in your family.
Ruth Rau
Main Street Architecture, P.C.
Thu, Jul 26, 2007 at 1:28:14 PM | profile in family
bobv
Ruth
No error inserting family.
Picture 1 shows profile. 2 is family
3 dialog of family. Notice after profile is inserted parameters are not read from profile.
4 is profile dialog
5 is catalog.
Thanks
bob v
26086_Picture1.bmp26086_Picture2.bmp26086_Picture3.bmp26086_Picture4.bmp26086_Picture5.bmp
Mon, Jul 30, 2007 at 7:39:31 AM | profile in family
kesflower
3.5 Stars: 11 Votes
What Revit version are you using?
 Rather than attatching a text catalog (even though they are so much faster), try making your catalog by using the generic interface of Family Types in the Family window.  You should be able to make a profile with the constraints you want in the family types dialog box.  then you should be able to load that constrained profile into the family where you can continue to incorporate it into a more complex family.  I'm honestly not sure why your text catalog is not working, but I know that you should be able to do it using the stock interface.
 Sorry that I cannot be of more help.
Ruth Rau
Mon, Jul 30, 2007 at 9:49:50 AM | profile in family
kesflower
3.5 Stars: 11 Votes
Or, have you tried making that profile inside your main family instead of nesting it?  Obviously nesting the profile in the family is preferrable so that you can use it in more than one family, but if you need it done quickly, it might be worth adding the parameters inside your main family.
Edited on: Mon, Jul 30, 2007 at 9:53:34 AM
Ruth Rau
Revit 2014 - Array within Profile Family
Fri, Aug 29, 2014 at 9:35:42 AM
Profile Family (Can't create instance)
Wed, Oct 21, 2009 at 11:39:04 AM
adjustable profile family
Fri, Jul 20, 2012 at 9:08:25 AM
Shared profile
Wed, Nov 11, 2009 at 9:40:38 AM
Using a profile parameter to define a sweep profile
Fri, Jul 19, 2013 at 9:31:17 AM
Page generation time: 2.2307
