Forums >> Revit Building >> Technical Support >> concrete form tie holes
Tue, Jul 24, 2007 at 10:49:40 AM | concrete form tie holes
matthew2540
i am trying to create form tie holes in concrete walls. I created a void and used cut geometry and it works fine except for the fact that i have to cut each one, so i have to cut a few hundred one at a time. does anyone know a faster way to do this?
Tue, Jul 24, 2007 at 11:16:15 AM | concrete form tie holes
broncos4life
3.5 Stars: 11 Votes
Combine all the holes into one void, not one void per hole.  Or you could just edit the profile of the wall and add thoes holes in, and then copy them around inside the wall profile editor.
Tue, Jul 24, 2007 at 11:49:53 AM | concrete form tie holes
matthew2540
thanks so much, you just saved me a lifetime! (what a simple solution too!)
Adaptive rectangular pattern with bubbly holes
Thu, Sep 12, 2013 at 6:31:28 AM
Cut holes in walls?
Thu, Jun 2, 2011 at 10:54:59 AM
Rebars - Stirrups Tie in Drafting View
Wed, Aug 1, 2012 at 9:47:36 AM
Revit 101 questions...(pertaining to UCS)
Sat, Oct 22, 2005 at 4:37:19 PM
Tapered, Curved, Concrete Retaining Wall
Mon, Jun 8, 2015 at 3:47:06 PM
Page generation time: 0.1131
