Forums >> Revit Building >> Technical Support >> Lines too heavy in perspective view
Tue, Jul 24, 2007 at 9:56:33 AM | Lines too heavy in perspective view
Hence
1 Stars: 1 Votes
Hi, the profile lines in my perspective view are way to dark.  I changed view properties and advanced model graphics to override the profile line to be thin lines, but they are still too thick. When i use the "Thin Lines" button on the tool bar i get a image that i feel looks clean and readable.  However, the image will not export with these lines.  How do i get the image on my screen, with thin lines, to exprort, and not get the ugly thick profile lines?
Thank you.
Tue, Jul 24, 2007 at 11:44:01 AM | Lines too heavy in perspective view
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can try the Settings-->Line Weights-->Perspective Line Weights tab. You can set the values for the 16 different lineweights to a small number. Not sure if this is what you are looking for but it is worth a try.
Tue, Jul 24, 2007 at 12:28:50 PM | Lines too heavy in perspective view
Hence
1 Stars: 1 Votes
Thanks that worked great.
Tue, Mar 10, 2009 at 11:30:44 AM | Lines too heavy in perspective view
matlock
matlock Avatar
4 Stars: 6 Votes
......Awsome......
Tue, Apr 30, 2013 at 3:30:18 PM | Lines too heavy in perspective view
annateo301
Does anyone know how to make this work in Revit 2013?
Tue, Apr 30, 2013 at 3:40:36 PM | Lines too heavy in perspective view
I don't understand.  The settings are still there for you to change.  Did you try it?
Wed, May 1, 2013 at 4:05:43 PM | Lines too heavy in perspective view
annateo301
I can't find 'Perspective Line Weights '
Wed, May 1, 2013 at 6:36:38 PM | Lines too heavy in perspective view
annateo301
Ignore me.
Found it! It's under Additional Settings>Line Weight> Perspective Line Weights
Floor lines showing through siding in perspective...
Tue, Apr 15, 2008 at 5:05:10 PM
12
Line styles won't appear in Perspective view
Tue, Sep 8, 2009 at 3:47:39 PM
Moving Objects in 3d Perspective View
Wed, Jul 27, 2016 at 3:52:14 PM
perspective view
Thu, Feb 7, 2013 at 1:47:34 PM
My bump lines are too thick and heavy. [ 1 2 ]
Thu, Aug 11, 2016 at 2:45:38 PM
21
Page generation time: 1.7551
