23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> How to achieve newell posts on winder stair
3 Posts No Rating |
Hi all, having some problems getting posts to show on the inner side of a stair with winders, in edit I have checked show posts on angles greater than 0.0 degree and have split the rail at the changes of height to the treads. Each section around the winder I have made flat all seems to work out but all I get is a post at the top of the stair and one at the bottom not on the winder itself. The stair is 15 treads, 3 traight up, then 5 risers at 30 degree angles then 7 more straight risers. There is 200mm gap between the two straight flights. The posts are 100mm square. This has been doing my head in all morning...someone please help as I expect its just the tick of a box..... Danny
Winder Stairs in 2013 |
Tue, May 8, 2012 at 12:49:31 PM
stair winder |
Thu, Jul 31, 2014 at 6:47:11 AM
Custom Stair Tread Profile vs. Default Tread Profile |
Tue, Apr 30, 2019 at 2:28:08 PM
partial wall miter below winder [ 1 2 ] |
Sun, May 3, 2009 at 12:21:40 PM
20
Monolithic winder stair |
Thu, Aug 22, 2013 at 12:50:18 PM
