18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Curtain Panel Glazing with Frit
14 Posts No Rating |
I would like to add a frit pattern to a portion of a curtain wall panel. How should I go about placing the frit such that it will appear in all views and renderings. Do I need to give it a materiality in order to achieve this? If so, or not, how then? If I want a variable (by instance or type) dimension to locate the frit, how should I establish a parameter for this dimension. I feel sorta silly asking this question, but the tutorials don't ever explain the why of any steps, so I have difficulty backwards-engineering how these pieces are supposed to work together. Using Arch-2008
Curtain system > glazing panel matherial |
Mon, May 28, 2012 at 1:02:14 PM
Doing a Frit in Revit |
Thu, Dec 13, 2012 at 9:55:52 AM
Replace blank curtain wall panel |
Mon, Oct 12, 2015 at 12:13:56 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Daylight Calculations for LEED |
Mon, Feb 14, 2011 at 5:56:41 PM
