Forums >> Revit Building >> Technical Support >> Brick cut pattern
Mon, Jul 23, 2007 at 5:00:19 PM | Brick cut pattern
utearch1
Probably an easy question, but is there a way to turn off the material cut view in a section without turning it off in a floor plan view?
Our firm likes to show the actual bricks in a section view, but a cross hatch in the plan view. I can use the repeating brick pattern in the detail components library, but when I turn off the cut pattern, it turns if off in the plan view.
Using 9.1
Thanks
Tue, Jul 24, 2007 at 8:52:01 AM | Brick cut pattern
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you are talking about in the materials dialog then no. The Plan and Cut view use the same pattern. This is something I hope Autodesk changes soon. What I have done is to make sure my detail component has filled regions and masking regions to cover up the cut patterns. I am pretty sure the default "2 Core CMU" detail component is set up this way.
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Material Surface and Cut Pattern accuracy
Mon, Jan 28, 2008 at 8:25:08 AM
Model Cut Pattern?
Wed, Jan 30, 2013 at 12:16:11 AM
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
Page generation time: 0.6581
