Forums >> Revit Building >> Technical Support >> Re-orientation of 'wall by face'
Sun, Jul 22, 2007 at 9:50:05 AM | Re-orientation of 'wall by face'
Vibrator72
I've created a moderately complex curved solid in Rhino and have taken it into Revit (2008 version) as a metric mass family.  It allows me to create a wall by mass but it is orientated the wrong way i.e. external material faces inwards.  How do I re-orientate the wall?  Perhaps I'm doing somthing wrong when I select the massing face?
Sun, Jul 22, 2007 at 9:53:03 AM | Re-orientation of 'wall by face'
Vibrator72
Just to add - I've used an acis sat file for the export/import.
Sun, Feb 13, 2011 at 4:41:20 PM | Re-orientation of 'wall by face'
joachimmargarit
I am having the same problem when i apply a curtain wall to the face of a mass. It would be good to know if there is any hard and fast rule that determines which way the wall will orientate. I have tried re-doing the mass surfaces with mixed results. Sometimes the wall orientates correctly, sometimes not. The mass was created within revit and not imported.
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
i changed the settings in the temporary dimensins and nothig changes y ?
Thu, Feb 9, 2006 at 3:45:33 AM
Problem using 'paint tool' within copied groups - Revit 2013
Thu, May 23, 2013 at 6:36:47 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
site orientation
Mon, Feb 18, 2008 at 1:35:35 AM
Page generation time: 0.7333
