Forums >> Revit Building >> Technical Support >> columns in walls
Mon, Dec 22, 2003 at 1:11:03 PM | columns in walls
amara
when adding a concrete column in wall (medium or fine detail), the column takes the hatching of the inside layer -gypsum od brick, and the column border in the wall depth disappears. Typically the column should be hatched with reinforced concrete hatching. When the column is flush with the internal face of the wall the column disappears. Is there a way to detach the column from the wall to make it show with border and identical hatch?
Mon, Dec 22, 2003 at 1:42:41 PM | RE: columns in walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Are you using the default modeling column? You should use a structural concrete column, it will show up inside your wall. Go to your structural tab and load in a concrete column from your structural library. I hope that helps.
Hiroshi Jacobs
Mon, Dec 22, 2003 at 2:13:46 PM | RE: columns in walls
amara
Thanks. I knew this one should be easy.
intersecting walls and columns
Tue, May 4, 2010 at 5:08:06 PM
Strucutral Columns VS Walls in Call outs
Mon, Aug 16, 2010 at 8:17:05 AM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:25 PM
walls and columns
Mon, Aug 29, 2011 at 5:54:46 PM
columns in walls
Mon, Sep 11, 2006 at 11:53:37 AM
Page generation time: 1.0413
