Forums >> General Discussion >> Revit Project Management >> QUESTION ABOUT FLOORS!!!
Fri, Jul 20, 2007 at 2:58:01 PM | QUESTION ABOUT FLOORS!!!
doza10
HAS ANYONE FIGURED OUT IF IT IS BETTER TO CREATE A FLOOR THROUGHOUT AN ENTIRE PROJECT OR TO DO IT IN DIFFERENT SECTIONS?
Fri, Jul 20, 2007 at 4:29:43 PM | QUESTION ABOUT FLOORS!!!
broncos4life
3.5 Stars: 11 Votes
You can do one floor system that is just your slab, and then do the finishes ie. carpet, tile, VCT, etc seperatly per rooms. Thats what we manily do and it seems to work best.
Sat, Jul 28, 2007 at 7:46:05 PM | QUESTION ABOUT FLOORS!!!
eldados
eldados Avatar
4.5 Stars: 8 Votes
not sure i understand the question? what do you mean by "THROUGHOUT AN ENTIRE PROJECT OR TO DO IT IN DIFFERENT SECTIONS?" are you refering to compound floors? if so, I tend not to use this method but rather separate the floors layers to their own floor type, this will give you greater control over the project.
does this answer your question?
Integrator
KarelCAD
Massing Question - Extending floors into wall core
Tue, Mar 4, 2008 at 10:27:59 AM
Question Anout Floors
Sat, May 15, 2010 at 10:31:36 PM
Duplicating floors and ceilings question
Fri, Feb 24, 2012 at 12:06:41 PM
Question about walls/floors and back splashes on Revit 2011
Mon, Jul 26, 2010 at 8:21:54 AM
Joining the Geometry of two floors
Wed, May 14, 2008 at 5:46:12 AM
Page generation time: 4.4119
