Forums >> Revit Building >> Technical Support >> Roof Joist
Fri, Jul 20, 2007 at 11:25:11 AM | Roof Joist
utearch1
Can someone help me on a roof joist issue. I have the joist set where I want it, but the end keeps extending over the beam it sits on. I need to bring the joist end to align with the edge of the beam so the bearing plate sits on the beam correctly. I keep trying to drag it with the blue dot, but it always jumps back to its original position.
Using 9.1
Thanks
Mon, Jul 23, 2007 at 10:38:02 AM | Roof Joist
rkitect
rkitect Avatar
4 Stars: 29 Votes
Long shot, but have you tried placing a referenc eplane wher eyou want the end of the joist to be to see if you can get a snp point there?  Also, try right clicking the blue dot and see if there is a "Disallow Join" option, if so, click it and try again.
Thu, Jun 5, 2008 at 7:37:29 AM | Roof Joist
Grr8
Grr8 Avatar
2 Stars: 1 Votes
I have similar problem with adjusting the custom 2.5K oist I created out of (4) 1 1/4 X 1 1/4 X 1/8 angles it only inserts into my projects at 10' which is the length I made it when I created it as a family with ref points. If you figured it out please let me know so I can make my 2.5K joist adjustable between 2' and 10' for different spans, thanks!
Thanks,
 Matthew Gore
ROOF AND JOIST
Wed, Mar 3, 2010 at 3:07:50 PM
Cuving Joist with Barrel Roof
Fri, Mar 6, 2009 at 7:46:53 AM
Sloped Structural Joist
Mon, Nov 7, 2005 at 12:14:32 PM
Dimensioning a Sloping Concrete Pan Joist Roof
Sat, Feb 14, 2009 at 11:07:40 AM
The iLevel TJI roof joist revit file
Fri, Jul 9, 2010 at 11:28:51 AM
Page generation time: 1.0550
