11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> "line is to short"
1 Posts No Rating |
why do I get this "line is to short" when i am trying to copy/monitor walls?
Just curious, how far are you trying to copy it Unfortunately, in Revit, there is a such thing as not mocing/copying something far enough away from the original location. Try moving/copying it further away than you need and then placing it where you want it.
Im drawing details and Im getting this errorElement is too small on screen is there a way around this???
you can use your arrow keys to "move" the lines/walls, or you can just copy it further away, and then move it to where you want it. I've found that 1/32" seems to be the magic number, if you try to move it less than that, or have a line smaller than that, the application screems at you. Anyone gotten smaller? I'd like to know how!
1 Posts No Rating |
Ok this is really annoying. I am doing a region fill showing a thickness of 0,5mm and it says "Line os too short". Only if I make the thickness 0,8mm then it accepts it. I have also got this problem with smaller circles / radius. Any sollutions?
HELP! "Line too short" error message |
Tue, Jul 24, 2007 at 11:00:01 AM
Looking for a short video to show executive team the "I" in BIM |
Fri, May 2, 2014 at 2:23:58 PM
Ramp Error - Line is too short - RAC 2008 |
Thu, Jan 24, 2008 at 4:20:24 PM
Going from "Title w line" to "Plan Title" |
Thu, Aug 23, 2007 at 11:53:11 AM
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:49 PM
