21 Users Online (19 Members):
Forums >> Revit Building >> Tips & Tricks >> Tiled Floors
Hello fellow reviteers!
I've been lurking here for a little while and have learned a bit in that little time. I would like to get some information on how to layout a tile floor pattern. I know it would probably be quicker in AutoCAD to just lay it out; but has anyone played with this idea in Revit yet.
Thanks for your time and I look forward to hearing from you. Keep up the great work and keep posting those wonderful inspirational renderings!
Carl
cgibson@rdesignworks.com
It all depends on how detailed a layout and complex are you talking?
I'd probably say i'd find it easier in revit. Its simple to tab select a surface pattern in a plan or elevation and move the desired location... You can also dimension to the surface pattern and move this way as well as rotate.
When i say surface pattern though, it must be simple pattern and not custom as these cannot be changed as easily...
Have views mirror one another when tiled... |
Wed, Oct 14, 2015 at 7:31:24 AM
Tiled View changing |
Fri, Apr 17, 2015 at 10:20:39 PM
tiled walls |
Mon, Nov 26, 2007 at 12:48:55 PM
Randomized Colors Tile Pattern |
Tue, Jul 8, 2014 at 1:20:02 AM
Floor at different level |
Thu, Jan 5, 2012 at 11:27:10 AM
