Forums >> Revit Building >> Technical Support >> Smart Family and Symbolic Lines
Wed, Jul 18, 2007 at 10:05:43 PM | Smart Family and Symbolic Lines
BradMEP
I realize that this should most likely be posted under the REVIT Systems forum since I am using MEP2008, but there is not much activity over there.
I am trying to make a "smart" diffuser family and I have been sucessful in makeing a 3D model of the diffuser that will change in size when I change a "length" and "width" dimension.
The problem I am having is that when I try to apply symbolic lines to the diffuser (Basically an X over a rectangle) I can't get the symbolic lines to change in size proportional to the "length" and "width" dimensions.
 Any suggestions would be appreciated
Henry Adams, LLC
Consulting Engineers
410-296-6500
Thu, Jul 19, 2007 at 9:13:02 PM | Smart Family and Symbolic Lines
puzzle
4 Stars: 10 Votes
You have to align then lock the ends of the symbolic lines to the width ref & then the length ref. draw them to the intersection then align them by tabbing through to pick the line end.
Hope this helps.
Macca
Sunshine Coast
QLD Australia
Fri, Jul 20, 2007 at 7:19:13 AM | Smart Family and Symbolic Lines
BradMEP
Thanks for your response, I got it to work.
I think my issue was I was not using reference lines to constrain my parametric variables to.
Henry Adams, LLC
410-296-6500
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic Lines Variation in Family
Thu, Feb 15, 2007 at 1:33:21 PM
Symbolic lines in elevation
Thu, Jan 10, 2008 at 7:12:53 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Page generation time: 8.8933
