Forums >> Revit Systems >> Technical Support >> Revit & 64bit compatability
Wed, Jul 18, 2007 at 1:33:50 PM | Revit & 64bit compatability
karthur
Is there a version of Revit currently available that is compatable with a 64 operating system?
Thu, Jul 19, 2007 at 3:57:50 AM | Revit & 64bit compatability
coreed
coreed Avatar
4 Stars: 16 Votes
far as i know there is not.
but i attend just about every seminar in my area given by Autodesk or major Autodesk training faculities, and i have heards rumors that the 64-bit(Vista Version) of revit is only 2-3 months away. hopefully there is some merit to those rumors.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jul 19, 2007 at 9:29:22 AM | Revit & 64bit compatability
broncos4life
3.5 Stars: 11 Votes
Depends on what you mean compatable...will Revit work/run on Vista?  Yes.
Is revit a 64 bit program yet? No.  That releas should be comming soon.
Wed, Sep 19, 2007 at 5:08:13 AM | Revit & 64bit compatability
vector23
vector23 Avatar
2 Stars: 16 Votes
when you speak of Vista you have to make clear you are
either talking about Vista32 or Vista64- huge difference..
no 32 bit anything will work with Vista64.. (other than
"emulation" for running old 32 bit apps in an emergency)
Vista32 is really just the new Vista GUI running on the
old NT/XP kernel.. and it doesn't run programs as well as XP..
there is not much purpose in Vista32- other than to
learn about the future.. i figure i will start learning Vista
when Revit goes 64 bit and then i buy new 64 bit hardware
and Vista64..
Wed, Sep 19, 2007 at 8:02:07 PM | Revit & 64bit compatability
sdbrown
5 Stars: 3 Votes
I'm running revit on xp64 and it is much faster than our other duo core machines and can take advantage of more ram.  But as others said revit will install as an x32 software.
Wed, Sep 19, 2007 at 8:39:44 PM | Revit & 64bit compatability
framerman
4 Stars: 13 Votes
I'm running Revit on Vista 64 bit and it all seems fine. Other programs....no. My Canon printer is a huge paperweight.
Fri, Feb 22, 2008 at 1:42:44 PM | Revit & 64bit compatability
notagain
notagain Avatar
4 Stars: 1 Votes
I have one guy working on 64-bit...no issues to date...but then again...windows working....is that an oxymoron
I really want this to work...some good things some bad
Fri, Feb 22, 2008 at 2:25:07 PM | Revit & 64bit compatability
NKramer
4 Stars: 9 Votes
There was mention of Revit 64 at the user group meeting out here. Basically they are working on it. 2009 will not initially be 64 bit capable but they are hoping to have a service pack that would enable 64 bit capabilities sometime in the middle of the year. If not then it should show up in Revit 2010.
BTW this came from someone who works for autodesk, but it was unofficial information.
Nick
Fri, Feb 22, 2008 at 3:45:48 PM | Revit & 64bit compatability
4 Stars: 205 Votes
I have a friend with XP 64bit and RAC 2008, so far, no issues, work fine and faster, just what he said... i'm working with XP32 bits but i also buy a Vista 64 bit and i think i will format my PC and install Vista and RAC2008, i tell you later what happen...
Tue, Feb 26, 2008 at 5:13:43 PM | Revit & 64bit compatability
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
I run Revit Architecture 2008 installed on a Vista Ultimate 64-bit system and they operate perfectly with no problems at all. So if you worried about Revit '08 not being compatible with a 64-bit system, dont be. AutoCAD on the other hand is a PAIN to get running on x64 system... but it is possible. I believe that Autodesk released AutoCAD 2008 in a 64bit version. So I would believe this option would be available in Revit 2009.
Edited on: Tue, Feb 26, 2008 at 5:45:20 PM
Sun, Oct 12, 2008 at 5:59:39 AM | Revit & 64bit compatability
#11
archdevil
i am working with revit architecture 2009, on windows xp professional x64 edition.
it's working fine. no problem occurs. it install as x32 bit application but it take the advantage of
huge virtual memory of 64 bit operating sys.
i have problem with autocad 2008 and 2009 of 32 bit edition.
""amd athlon X2 dual core 4200+
   2gb ram
   256 mb nvidia 6600
   256 gb hdd and my infinite GB of brain""
Sun, Oct 12, 2008 at 6:01:11 AM | Revit & 64bit compatability
#12
archdevil
   2gb ram
   256 mb nvidia 6600
Sun, Oct 12, 2008 at 8:50:00 AM | Revit & 64bit compatability
#13
coreed
coreed Avatar
4 Stars: 16 Votes
hi archdevil, the 64-bit version is available now, no ram limit, it runs just fine
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Nov 3, 2008 at 9:54:55 PM | Revit & 64bit compatability
#14
xinxintangben
软件平台: Microsoft(R) Windows(R) XP Professional x64 Edition
                      SandraProBusiness v2009CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+Speed : 2.61GHzSystem BIOS : Phoenix Technologies, LTD 华硕M2N-E ACPI BIOS Revision 1102Total Memory : 8GB DIMM DDR242GBVideo System: NVIDIA GeForce 8600 GT  (512MB DDR2, 500MHz/1.16GHz/2x499MHz, PCIe 1.00 x16, PS3.0, VS3.0, 2 Heads)硬盘:ST3320620SV 320GB (SATA300, 3.5", NCQ, 16MB Cache) : 298GB (CSmile (DSmile (ESmileST31000333AS 1TB (SATA300, 3.5", NCQ) : 932GB (HSmile (ISmile光驱:HL-DT-ST DVD-ROM GDR8163B (ATA33, DVD+-R, CD-R, 256kB Cache) : N/A (ZSmile声卡 : ASUS MCP55 High Definition Audio网卡 : NVIDIA nForce Networking Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)显示器: Dell E177FP(1280X1024)                ViewSonic 26&rdquoCrying1900X1200)
Revit 64bit & RAM
Tue, May 4, 2010 at 9:02:19 AM
compatability
Tue, Jul 21, 2009 at 10:42:21 AM
Stupid compatability question
Tue, Mar 29, 2011 at 8:29:14 AM
64bit demo
Mon, Jan 12, 2009 at 10:24:22 AM
Designjet printer driver w/ Windows 7 - 64bit
Thu, Feb 17, 2011 at 11:20:24 AM
Page generation time: 1.3900
