Forums >> Revit Building >> Technical Support >> Wall Sweep Object Style?
Wed, Jul 18, 2007 at 11:01:18 AM | Wall Sweep Object Style?
blake
3 Stars: 2 Votes
How do you change the object style of a wall sweep that was added in the wall edt mode.  I know how to change a normal wall sweep object style but it does not work the same way.
Wed, Jul 18, 2007 at 11:36:49 AM | Wall Sweep Object Style?
superelboogie
If a sweep is added to a wall in edit mode, it becomes part of the wall as far as object style goes. You cant override it. I was hoping that 2008 would solve this dilema, but alas... no dice! Sad If anyone has any swell advice on visibilties seperate from walls set for the sweeps in elevations, I'd love to hear it!
~L
Detail Component Object Style?
Fri, Apr 9, 2010 at 10:01:48 AM
Wall Hidden Lines and Object Styles
Tue, Jul 31, 2007 at 11:47:48 AM
OBJECT STYLE ISSUE
Fri, Jan 30, 2015 at 10:34:36 AM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Object Style not showing unless object highlighted
Thu, Jun 8, 2017 at 3:29:24 AM
Page generation time: 2.9234
