Forums >> Revit Building >> Technical Support >> Deleted dimensions, door tags and window tags
Wed, Jul 18, 2007 at 2:46:25 AM | Deleted dimensions, door tags and window tags
werdup
Hi I am currently using Revit 9.1
I have moved a block of my building.
I done this by orientating a 3D view to top view to enable selection of all elements.
When I moved the block I got an error warning saying that the dimensions, door tags and window tags will be deleted.
The block is 5 storeys high and all the internal walls had been dimensioned, sos there is alot of abortive work to add the dimensions etc. to be added back.
Any ideas why this information was deleted.
Thanks
Wed, Jul 18, 2007 at 7:23:07 AM | Deleted dimensions, door tags and window tags
Are you sure you got everything?
...... The answer should be NO because you used a 3d view.  No 2d elements here!
Use a 2d plan (or elevation) with view range set to include everything and make sure evrything is on in VG (All tabs).
Wed, Jul 18, 2007 at 10:47:17 AM | Deleted dimensions, door tags and window tags
werdup
Thanks
When you say view range set to include everything is it best to do this in a roof plan and set the view depth level to the and bottom primary range to the lowest level of the model?
Wed, Jul 18, 2007 at 10:57:29 AM | Deleted dimensions, door tags and window tags
I usually go overboard in both directions and make sure that my view plane is well above everthing.
Door and window tags
Thu, Nov 3, 2011 at 8:51:34 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:10 PM
window/door tags
Mon, Oct 23, 2006 at 6:35:45 PM
Window tags
Wed, Dec 15, 2010 at 7:39:59 AM
Schedule and Tags
Fri, Sep 23, 2011 at 2:32:25 PM
Page generation time: 2.9008
