26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> Subcategory Layers, Colors, and Linetypes translation
Subcategory translation to AutoCAD drawing file is not assigning the correct layer and line color when translated out using an rte (template) we created. Examples of the subcategories under S-Wall we created are: S-Wall-Conc, S-Wall-CMU, S-Wall-Steel, S-Wall-Wood; with varying colors representing NCS layers, line-weights, and linetypes in plan and projection views respectively. Going through the Revit help, custom layer mapping modifications are translating out to their major S-Wall setting without translating out to the defined subcategories. The new template is in view during translation as the selected translate to file template. What would a correct or better measure to use? This is why we should have a translate to NCS standards selection.
How to export CAD with custom subcategory layer |
Tue, Feb 15, 2011 at 10:08:37 AM
Colors and Printing |
Thu, Jul 19, 2012 at 10:11:31 AM
imported dwg lineweights, linetypes |
Fri, Aug 10, 2007 at 9:22:53 AM
Change linetypes of a wall |
Thu, Jul 1, 2010 at 4:12:41 AM
Help for my curtain wall |
Tue, Jan 7, 2020 at 8:21:54 AM
