Forums >> Community >> Newbies >> objects
Tue, Jul 17, 2007 at 10:55:51 AM | objects
Bartelson
Bartelson Avatar
where do you guys make the objects, the furniture and everything else. is it revit. or can it be done in inventor, then transfered to revit. please help
Tue, Jul 17, 2007 at 11:26:50 AM | objects
For hard, flat plane shapes, REVIT works great so I build families like that in REVIT.  Soft, 3 dimensionally curved shapes are harder to model in REVIT so I use AutoCAD to develop the 3d meshes for that.
You can directly import AutoCAD 3d forms into a REVIT family.  Just make sure each 3d form that has a unique finish/color is on its own layer (exmpl - car bumper shape on bumper layer).  By doing this, you can assign a accurender material to the layer in your family.
If you look at some of the families, like cars, on this site, you can get a better grasp of how to do this.
Tue, Jul 17, 2007 at 3:57:38 PM | objects
Bartelson
Bartelson Avatar
hey thanks, but im still wondering if you can make them in inventer
Tue, Jul 17, 2007 at 4:09:19 PM | objects
I'm not familiar with inventor but I know REVIT only imports dwg, dxf, dgn, sat & skp formats.  If inventor saves in one of those then why not try something and let us know how it works?
Thu, Jul 19, 2007 at 1:53:46 PM | objects
Bartelson
Bartelson Avatar
well i dont have it on my computer at work, but i do at school. so ill have to wait for next tuesday to find out.
Thu, Jul 19, 2007 at 2:08:40 PM | objects
broncos4life
3.5 Stars: 11 Votes
From what I have seen inventor saves as either an IDW or a IPT file, and so these wont come into Revit directly.  You can however you can indirectly get an invetor file to save either to a dwg or a sat file.  Refer to website
http://72.14.253.104/search?q=cache:ruepvjQvnoIJ:www.inventorconnections.com/connectqna_submitanswer.php%3Fcpfeatureid%3D20610%26PHPSESSID%3Daa4f2366cdff7bd32ec7dc6d8100d4cf+Autodesk+Inventor+File+Types&hl=en&ct=clnk&cd=5&gl=us
They explaine how to change your inventor file to a dwg or sat file, then you can either bring the dwg or the sat file into Revit.HTH
Grant Doherty
Fri, Jul 30, 2021 at 12:11:36 PM | objects
hanbyjm
My boss inserted a familiy made from an inventor file.  It has slowed the model down alot!  When I try to explode the .ipt file in the family model file, everything disappears.  Is there anything we can do to speed the model back up?
Fri, Jul 30, 2021 at 2:38:56 PM | objects
Edit the family to include symbollic, 2D linework and set it to only show the 3D model in 3D views
Fri, Jul 30, 2021 at 2:44:01 PM | objects
Another means of improving speed when you have very large files is to put the family in a special workset and only load that workset when you really need to see the object.
Fri, Jul 30, 2021 at 3:08:27 PM | objects
hanbyjm
We did that and it is still super slow.
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
please help- tried everything to get objects to accept material...
Thu, Apr 16, 2009 at 12:45:04 AM
Placing objects in 2D, but cant see the in 3D.
Fri, Jun 22, 2012 at 2:21:51 PM
How to Scale Objects in Revit
Fri, Aug 25, 2017 at 1:13:47 PM
Mid-Point between two objects?
Thu, Oct 4, 2007 at 3:15:28 PM
Page generation time: 0.3388
