Forums >> Revit Building >> Technical Support >> Fillet Command
Tue, Jul 17, 2007 at 9:58:14 AM | Fillet Command
MrBob
3 Stars: 2 Votes
Does Revit have a way to trim two lines with a rounded line outcome like AutoCAD has the fillet command?
Tue, Jul 17, 2007 at 10:03:55 AM | Fillet Command
broncos4life
3.5 Stars: 11 Votes
Yes, when you are drawing lines and such, you have 3 regular choices "Line", "Rectangle", and "Arc passing through three points"  next to the third is a drop down arrow...click on that and in that list is "Fillet Arc" and click that, then click the two lines you want to fillet and then click the radius.
Tue, Jul 17, 2007 at 10:47:07 AM | Fillet Command
MrBob
3 Stars: 2 Votes
Thank you very much!
Adding fillet to circle mass
Tue, Jun 5, 2012 at 6:29:31 AM
fillet arc on stairs
Fri, Oct 28, 2011 at 12:39:35 PM
Stacked wall problem - corners do not fillet.
Wed, Jul 16, 2008 at 11:40:39 AM
Fillet to wall
Sat, Apr 16, 2011 at 9:14:46 PM
Fillet arc not working on baluster panel extrusion
Wed, Oct 26, 2011 at 5:56:34 AM
Page generation time: 0.6801
