Forums >> Community >> The Studio >> Setting the materials for symbol families
Thu, Jan 20, 2005 at 10:23:43 PM | Setting the materials for symbol families
Sleepless
How do I set the materials for families like cars, furniture and so on which are based on dwg or other imported formats?
Thu, Jan 20, 2005 at 11:09:39 PM | RE: Setting the materials for symbol families
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You cannot make these materials parametric (for 3d DWG imports), however you can still change the materials. In the family, check out the material settings, you will notice a bunch of imported ones these are associated with the dwg, and if changed will also change the model.
Fri, Jan 21, 2005 at 11:02:10 AM | Thank you Mr. Spot
Sleepless
After I kept trying I also figured out that the dwg layers become listed in the material library... Thank you for this quick response Sleepless
Sharing Materials in a network setting...
Sun, Oct 2, 2005 at 6:44:31 PM
Weld symbol editing
Thu, Jan 6, 2011 at 9:50:16 PM
electrical symbol families
Fri, Jun 5, 2020 at 3:57:35 AM
new symbol from 2009 wont load as symbol in 2011
Wed, Jul 6, 2011 at 2:09:39 PM
Applying materials to new families
Mon, Jun 19, 2017 at 10:28:03 AM
Page generation time: 0.8480
