Forums >> Revit Building >> Technical Support >> Unable to duplicate a view
Mon, Jul 16, 2007 at 7:06:30 PM | Unable to duplicate a view
AR1237
I have a 2 story building using revit architecture 2008. I can duplicate all other views with no problems. But, when I try to duplicate level 1 an error message appears and says, "Work Planes cannot be copied" It only allows me to cancel. I am not sure what I should do. I would like to duplicate the view to have mulitple plans showing, deminsion and room names.
 I have tryed duplicate and duplicate with details, both show the same error message.
Any help is appreciated.
Edited on: Mon, Jul 16, 2007 at 7:07:56 PM
Wed, Aug 8, 2007 at 3:48:39 PM | Unable to duplicate a view
AR1237
I have solved my own problem.  After thinking way too hard about it I discovered that I had turned of the visibility of the work plane in Level 1 view.  To fix the problem I pressed the reveal hidden elements button at the bottom.  I then highlighted everything then using the filter selected just the work plane grid.  I then right clicked and unhide element.  This allowed me to duplicate the view.
Thu, Dec 9, 2010 at 8:15:57 AM | Unable to duplicate a view
Dafpfy
3.5 Stars: 11 Votes
I have a similar problem now in RAC 2011,
the only difference is that i m not getting an error message,
i just try to duplicate or convert view to indepentant,,, revit thinks for a few seconds, , and nothing happens.
I dont realy understand how you solved your problem there,
any advise for this in rac 2011 ?
Edited on: Thu, Dec 9, 2010 at 8:16:39 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Sep 13, 2011 at 6:44:21 PM | Unable to duplicate a view
bongguerra
same problem with me here. I need to duplicate a similar plan view target on a floor plan. help please!
Unable to Duplicate Schedule
Wed, Sep 12, 2012 at 3:43:41 PM
Duplicate view
Wed, Jul 15, 2015 at 1:50:18 PM
Duplicate elevation view
Wed, Jan 11, 2006 at 4:41:27 AM
Creating duplicate views of elements
Tue, Apr 24, 2012 at 5:57:37 AM
Duplicate views create duplicate callout tags in referring views...
Fri, Mar 9, 2012 at 1:37:25 PM
Page generation time: 6.0016
