Forums >> Revit Building >> Technical Support >> Revit 2008. Volume not calculating. Any suggestions?
Fri, Jul 13, 2007 at 11:55:29 AM | Revit 2008. Volume not calculating. Any suggestions?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
As discussed in my thread below about trying to get an automatically filled ceil hgt column in my room schedule.
Fri, Jul 13, 2007 at 12:09:45 PM | Room Tag won't show volume either.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I don't find any option to make the ceiling "room bounding" like you can walls.  I find no help in the Revit Architecture 2008 "Users Guide" either.
Mon, Apr 11, 2011 at 8:35:14 AM | Revit 2008. Volume not calculating. Any suggestions?
newrevituser
In Revit Architectural 2011,
Click on Home Tab -> Room & Area expanded Panel (drop down list) -> Area and Computations.
In the Area and Volume Computations dialog box, highlight the Areas and Volumes checkbox.
If the Area and Volumes is highlighted, you will be able to see that the room height will follow the ceiling/roof surface in the section view (note: as long as the room height is higher that the ceiling/roof)
Hope it helps.
Calculating Volume
Tue, Sep 4, 2007 at 2:35:09 AM
Suggestions on Revit 2008 Books?
Tue, Feb 5, 2008 at 1:30:36 PM
Volume formula issues
Mon, Jul 7, 2008 at 8:44:09 AM
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
Looking for Rendering Suggestions on a Revit 2008 Accurender Rendering..........
Wed, Nov 4, 2009 at 4:41:36 PM
Page generation time: 2.3352
