21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Can the room schedule have a column that automatically fills in ceiling height?
Since area and volume are available as room schedule columns with automatic fillin of those amounts, why not a ceiling height column? Anyone know a way to set this up?
I created a ceil hgt column, set it up to calculate "Volume/Area", set the cells to be "lengths" as well as all the other possibilities, but have had no luck getting ceil hgts to show up. Any suggestions?
I am unable to edit the formula on "Volume" since I guess it is controlled within the project. I checked the ceiling family and don't find any way to make it "room bounding" like you can the walls. Is there some setup problem that could cause the ceiling not to allow the volume to be calculated? When I select a room's ceiling and click on its "properties" there is a volume category shown. It apparently is the area of ceiling times its thickness because it is way less than the actual volume would be. I guess this is a generic volume of any item selected not of the space that it encloses. Any suggestions? Anyone? Anyone?
Room Schedule-Can I get the ceiling height to be automatically calculated? |
Mon, Sep 22, 2008 at 10:46:23 AM
Room schedule with ceiling height |
Fri, Jul 13, 2007 at 11:01:42 AM
Ceiling height in Room Schedule |
Sun, Apr 5, 2009 at 12:44:47 PM
Add Ceiling Height in Room Schedule |
Mon, Nov 19, 2012 at 9:38:54 AM
CEILING HEIGHT IN SCHEDULE |
Mon, Feb 18, 2019 at 6:34:48 PM
