Forums >> Revit Building >> Technical Support >> reloading updated template....?
Fri, Jul 13, 2007 at 1:19:53 AM | reloading updated template....?
coske
hey guys
im quite new to revit, probabbly about a week, and im stuck on one thing that i just cannot work out.
preety much, i got old template, which i have updated (added new legend sheet, and saved it over then current template...meaning i opened old template, edited it, saved the changes)...
problem that is rather pissin me off is that i cannot work out how to reload new template over the old drawings...new drawings with new templates are ok...old drawings with old templates cannot be updated....
if someone can help, or has a solution, pls let me know
kind regards me
Fri, Jul 13, 2007 at 8:31:04 AM | reloading updated template....?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
With your current drawing open, Open your new template and click File-->Transfer Project Standards. This will allow you to transfer most of the stuff from your template to the current project.
Sat, Jul 14, 2007 at 9:10:26 PM | reloading updated template....?
coske
i have tried that, and it does transfer all the things...appart from that new created sheet...
Sat, Jul 14, 2007 at 11:48:34 PM | reloading updated template....?
ale02
ale02 Avatar
3 Stars: 3 Votes
maybe u can try to export or link your old revit project to your brand new blank revit project (reload using new templete).. hope that helps
Life is never easy but nor it should be complex. Just stay simple Smile
Sun, Jul 15, 2007 at 3:49:02 PM | reloading updated template....?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There is no way to apply a template file to an already existing project in an automated way.  Basically whatever template you start with is what your stuck with for the duration of that project.
That said you can:
Use transfer project standards to get the bulk of the settings across.
And Use Load Family to load any new content you want in your project...
HTH.
Regards,
Chris.
Mon, Dec 15, 2008 at 2:37:26 PM | reloading updated template....?
MDAdave1999
Since you have to start a new project in order to get your updated template file loaded.....is it okay to start a new project, then copy and paste my old project into it?
Do you foresee any issues with that?
Or should I link in my Old Revit project to a new project?
Tue, Dec 16, 2008 at 6:40:23 AM | reloading updated template....?
tim123
4 Stars: 19 Votes
Open the sheet and your project.  Go to the sheet and 'Load into Project'.  This should overwrite your current sheet.
Tue, Dec 16, 2008 at 8:11:31 AM | reloading updated template....?
MDAdave1999
Thanks for getting back to me.  But it didn't take.
I opened both projects and while I was in the existing project, I "loaded in Projects" and acted like it was doing something then nothing happened.
Tue, Dec 16, 2008 at 12:07:45 PM | reloading updated template....?
tim123
4 Stars: 19 Votes
When you are in your project are you able to edit your sheet family, change something and reload it into your project?
Tranfer Families between projects
Thu, Apr 22, 2010 at 9:43:55 AM
Template Update
Sat, Jun 25, 2016 at 6:01:29 PM
"can't find solutions for formulas" error
Wed, Aug 3, 2016 at 5:46:21 PM
Transfer Project Standards not working
Tue, Jan 7, 2014 at 5:14:44 PM
Saving/unlinking a Workset Without Updating
Wed, Oct 1, 2008 at 11:05:31 AM
Page generation time: 0.1300
