Forums >> Revit Building >> Technical Support >> spiral wall
Sun, Dec 21, 2003 at 1:41:34 PM | spiral wall
amara
I was trying to do a spiral wall (circular wall with varied elevation profile) with no luck. The option to "edit elevation profile" disappears with curved walls. In ADT you can do this easily with "edit roof/floor line". Thnks in advance
Sun, Dec 21, 2003 at 2:58:06 PM | RE: spiral wall
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
to do this you're going to have to create an in-place family using solids and voids. You would create your circular wall with a solid and then cut away from it with voids, probably multiple voids in this case.
Hiroshi Jacobs
The Catholic University of America
Mon, Dec 22, 2003 at 1:03:18 PM | RE: spiral wall
amara
For a revit beginner this sounds too complicated. I find revit outstanding but the ability to do custom made items worries me. In ADT there is always ways to manipulate - while getting the job done is way too complex!!! I wish there is a way to get the best of both...
Mon, Dec 22, 2003 at 1:08:24 PM | RE: spiral wall
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Some would say that the thought behind revit is to build buildings like they're really built...and if it's difficult to build in real life, you should take the time to think about it while modelling it. I do agree however that some complex modeling should be a little bit easier in Revit. I find revit to be about 10 times more efficient than ADT for most other things though. And keep in mind that you can import DWF's into Revit as 3d objects...
Hiroshi Jacobs
Help - curtain wall on spiral ellipse
Mon, Oct 11, 2010 at 6:02:04 PM
Stair with Spiral Wall raling
Fri, Sep 28, 2007 at 12:47:22 PM
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Spiral Extrusions
Mon, Feb 1, 2010 at 5:40:22 PM
Beam attached to s spiral slab
Sun, May 26, 2013 at 7:07:46 PM
Page generation time: 3.2964
