Forums >> Revit Structure >> Technical Support >> Floor Plan View Range - Viewing a half storey
Thu, Jul 12, 2007 at 3:21:53 PM | Floor Plan View Range - Viewing a half storey
Silva
I have an instance where i want to view a mid landing Lobby c/w stairs going up to it (without a cut line) on my Ground Floor Plan.  The Lobby Level is 7'-0" above the Ground Floor Plan.  If I set my cut plane to anything less than 7'-0", my lobby level won't view and the stairs are graphically cut.  If I set the Cut Plane to anything greater than 7', then the door swings on the ground floor don't appear (all doors at 7'-0" high.  Is there an easy way of solving this?
Thanks!
 Silva the Newbie
Thu, Jul 12, 2007 at 3:32:23 PM | Floor Plan View Range - Viewing a half storey
justinblack
I believe what you are looking for is plan region.  You should be able to select the area and give it a different view range.
HTH
JB
Edited on: Thu, Jul 12, 2007 at 3:33:02 PM
Can't see first storey walls in first storey plan view
Mon, May 5, 2014 at 9:02:22 PM
MUlti storey floor plan view sheet alignment
Wed, Jul 19, 2006 at 1:34:05 PM
I can not figure out teh "View Range" in revit 2013
Fri, Aug 30, 2013 at 12:54:18 PM
Light switches not showing on floor plan
Fri, Apr 29, 2011 at 2:14:19 PM
Plan Region and View Range issue
Tue, Sep 26, 2017 at 7:27:30 AM
Page generation time: 1.6634
