Forums >> Revit Building >> Technical Support >> importing autocad title blocks
Thu, Jul 12, 2007 at 8:10:42 AM | importing autocad title blocks
teamleader1
I am trying to create a Revit Title Block and would like to import an autocad file into the 22 x 34 Revit Title Block so I can trace it rather than create a new one.
  When I loaded it, it gives an error message.
 Can not import proprietary components.  Try exploding, change proxygraphics to 1, and explode.  I tried this but without success.
 I have opened the visibility tab and it shows the layers have been imported but nothing shows up.
Working in 9.1
Thanks
Thu, Jul 12, 2007 at 3:44:44 PM | importing autocad title blocks
framerman
4 Stars: 13 Votes
I think the only thing you really want to import into a titleblock from AutoCAD would be the lines. You would want to use Revit's capabilities to adjust items for you in the project information part. You don't need to trace the lines though. If you explode the lines after importing, it should be fine.
I'm not sure what the proprietary components are that you are talking about though.
Creating a new one shouldn't be that much of a job if you need to.
AutoCAD Blocks Importing
Fri, Sep 8, 2006 at 3:36:38 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:00 PM
Customize new Title Blocks
Mon, Sep 21, 2009 at 2:55:19 PM
ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 5:26:46 AM
Page generation time: 2.4225
