8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Families and hosts of families
7 Posts No Rating |
Is there a way to create a component that will take on the full size of a host. What I am trying to do is create something that will designate the occupancy use and I can attach to a floor that will change when a floor plate changes size. The idea is that I can give the component a color to associate it with an occupancy type and be able to get a square footage calc out of it as well. Thanks
This sounds like you may more luck with project parameters and playin with the Room parameters in a project than making a family component. I would look into that approach before spending much more time with fmaily components to achieve that. You can then set up an Area color scheme to indicate your occupancy types and a room annotation to indicate occupancy loads and type. HTH
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
7 Posts No Rating |
Will that color it in section though?
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
Scheduling multiple parking families |
Wed, Sep 7, 2011 at 7:50:18 AM
Revit Families |
Fri, May 24, 2013 at 4:23:33 PM
12
Edit Default Families |
Sun, Jan 24, 2010 at 8:23:42 AM
Selecting Nested Families |
Mon, Apr 13, 2015 at 12:30:53 PM
