Forums >> Revit Building >> Technical Support >> walkthrough will not export
Wed, Jul 11, 2007 at 8:21:41 AM | walkthrough will not export
shkuv
I am using Revit Architecture 2008 and I am having trouble getting a walkthrough to export.  I can set the walkthrough up and edit it just fine, but when I want to export it to an .avi, nothing happens.  I know a save as dialog is supposed to appear when I go to File>Export>Walkthrough, but when I click the menu the screen just flashes and nothing appears.  Is there a setting I need to worry about here or what?  I even called a support line that was setup by the place I got the software from and they were no help.  Any input is much appreciated!
Wed, Jul 11, 2007 at 11:22:41 AM | walkthrough will not export
rkitect
rkitect Avatar
4 Stars: 29 Votes
Be sure the walkthrough view is open and active when you do the export.  Otherwise it will just stare back at you like "what?"  Also, you need to be sure you have a codec that can encode into AVI (DIVX, Cinepack, etc) in order to save to an AVI file.
Wed, Jul 11, 2007 at 3:23:35 PM | walkthrough will not export
shkuv
rkitect, all of the things that you mentioned I have done.  I can create a walkthrough in any other project I have done so far, but not this one for some reason.  I have a presentation on Friday that needs to include a rendered walkthrough of this building and nothing seems to be helping.  I even got in contact with Autodesk and their suggestions aren't working yet.
 If anyone has experience with this problem, please give any input you can.
 thanks
Wed, Jul 11, 2007 at 6:00:48 PM | walkthrough will not export
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In that project if you create another quick walkthrough, when trying to export will that new view bring up the window?  It may in fact be that particular walkthrough that is corrupt and it may be quicker to regenerate it.  There is no point in trying to duplicate it as they will most likely bring the corruption with it.
Let me know if this helps or not.  I haven't experienced that issue before.
Regards,
Chris.
Thu, Jul 12, 2007 at 8:52:31 AM | walkthrough will not export
shkuv
I figured it out at the end of the day yesterday.  Apparently I wasn't opening the walkthrough properly by showing the camera first and then opening and exporting.  Thanks everyone for your help!
Thu, May 22, 2008 at 10:48:16 AM | walkthrough will not export
jhagens
I'm having that exact problem and I'm not sure how to fix it - I've even downloaded divx and still no change. shkuv: How did you figure it out exacly? Thanks.
Thu, May 22, 2008 at 10:59:44 AM | walkthrough will not export
jhagens
Tue, Jan 13, 2009 at 9:45:30 AM | walkthrough will not export
lilking57
I am getting that same problem!! The "Save As" dialog never pops up.  Can anyone help me?!
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
How to export walkthrough path to Viz 2008. Need reply by 11/15/07
Tue, Nov 13, 2007 at 3:30:39 PM
Walkthrough Export - White Border
Tue, May 22, 2018 at 1:20:29 PM
Walkthrough avi export - please help
Mon, Feb 21, 2005 at 12:23:46 PM
it s possible export a rendered video - walkthrough ?
Fri, Sep 26, 2008 at 8:16:54 AM
Page generation time: 0.1782
