Forums >> Revit Structure >> Technical Support >> instance of window not cutting anything
Tue, Jul 10, 2007 at 4:58:12 PM | instance of window not cutting anything
Micah
I keep getting an error message upon trying to load an edited window family which states, "instance of *window* not cutting anything"  it then proceeds to give me the option of deleting the window i'm trying to insert into the wall or letting me cancel the action.  Point is, i can't insert the window, or figure out how to avoid the error.  I have tried using voids instead of an opening cut in the window family but i get the same error.
The same window was working just fine, until i began to edit the muntins that i had previously added to it, and delete/rearrange the associated reference planes.  I suspect the issue is tied to this but i have yet to figure out the cause or how to correct/workaround it.
Any help would be useful, thanks.
Fri, Jul 13, 2007 at 12:05:31 PM | instance of window not cutting anything
I see that nobody answered this for you so I'll give it a shot.
When you readjusted your window, you probably changed where the opening cut is for the window and that is above or below your wall.  REVIT can't cut the opening bevcause there is no wall there.  Recheck your insertion elevation in your model.  A goo test would be to darw a wall a couple of hundred feet tall (100' up / 100' down) and put it in that, then you'll probably see it.
Floor Plan - Window Cutting Problem
Fri, Jan 7, 2011 at 4:16:59 PM
Window not cutting wall
Wed, Mar 2, 2016 at 3:34:28 PM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:50 PM
Window not cutting furred wall
Tue, Feb 14, 2012 at 12:56:04 PM
Instance Parameter for Variable offset from Ref Level Not behaving Window Fam
Wed, Nov 5, 2014 at 4:15:32 PM
Page generation time: 2.8652
