29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Pilaster Problem
56 Posts No Rating |
Can someone help me with the attached image. I can't seem to find a way to not have my walls run through my pilaster. The framing is fine, but not the finish. I have tried join and unjoin, but nothing seems to help. A detail call out of this would be tough looking like this. Thanks Revit 9.1
Join should work for this, you may need to reload the column family. I've had old columns not behave properly, also pick the masonry wall first then the column. Also make sure the column is the proper height. If all else fails use a filled region. But this should be possible. If you copy the walls and col to a sep file and post it I'll give it a try.
Concrete Pilaster at wall intersection |
Tue, Sep 28, 2010 at 11:16:08 AM
Piers/Pilaster joins |
Mon, Apr 28, 2008 at 8:50:54 AM
Pilaster |
Sat, Jun 30, 2007 at 10:15:22 AM
why the line? |
Thu, Jan 21, 2010 at 12:08:36 PM
A corner pilaster |
Mon, Jan 18, 2010 at 6:49:29 PM
