26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> convert metric to standard
17 Posts No Rating |
Is there an easy or any way to convert a component/ family from metric dimensions to standard inch dimensions?
Settings-->Project Units Revits dimensions are smart also. In metric or imperial you can type dimensions in the opposite format and revit will do the conversion instantly. HTH.
Regards,
Chris.
also is there a way to get the dimensions within the component to switch from reading metric to inches?
"also is there a way to get the dimensions within the component to switch from reading metric to inches?" As I showed above... GOTO Settings-->Project Units Change your Length, Area & Volume units as required... Doing this automatically updates the model.
Edited on: Tue, Jul 10, 2007 at 6:14:58 PM
Regards,
Chris.
Imperial to metric |
Tue, Apr 27, 2010 at 10:53:09 PM
problems printing in metric |
Wed, Aug 13, 2008 at 9:52:13 AM
my metric librarys gone? |
Thu, Apr 17, 2008 at 12:35:27 AM
from inches to meter |
Mon, Feb 9, 2004 at 6:36:53 AM
showing metric and imperial elevations |
Thu, Jun 3, 2010 at 3:34:46 PM
