16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> Beams in Column Schedule
4 Posts No Rating |
The columns in my structure are interupted by floor beams in a number of locations. I've created a graphical column schedule and where the beams interupt the columns there is a blank gap - is there a way to get the beams to appear in the schedule? Thanks in advance.
I assume structural framing is turned on in your visibility settings?
Regards,
Chris.
4 Posts No Rating |
Yes, structural framing is turned on in the visibility settings. As a second issue - for whatever reason the program will not allow me to change to the Top Connection Symbol to a splice for any of my columns (the only option under the pull down menu is "None" and the Base Plate Symbol option isn't even accessible.....any thoughts?
Concrete Beams not extending to Column C/L |
Wed, Jan 28, 2009 at 8:26:37 AM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Column Schedule |
Mon, Apr 21, 2008 at 7:35:29 AM
Beams and column joins, can I turn them ofF? |
Mon, Jun 2, 2008 at 8:17:31 PM
Column Schedule Help!!! |
Fri, Feb 20, 2009 at 11:39:39 AM
