Forums >> Revit Building >> Technical Support >> trimming a countertop?
Tue, Jul 10, 2007 at 11:23:59 AM | trimming a countertop?
ledge
is it possible to notch out a counter top around a wall or column?
Tue, Jul 10, 2007 at 11:30:39 AM | trimming a countertop?
sdbrown
5 Stars: 3 Votes
You will need to select the countertop and modify the family adding a void for the notch. you can put a dim on the void and have it move out of the way if you want one counter to be cut and another not to be.  Or just make 2 families.
Tue, Jul 10, 2007 at 11:51:24 AM | trimming a countertop?
ledge
thank you what would be the best way to create the 2nd family that you mentioned earlier?
Having trouble trimming countertop
Fri, Apr 15, 2011 at 10:34:16 PM
Countertop Invisibility
Mon, Jan 5, 2009 at 1:46:39 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled?
Tue, Mar 28, 2006 at 3:39:10 PM
Anyone ever put a countertop on a wall as a sweep? Anyone?
Wed, Nov 15, 2006 at 3:42:51 PM
cannot get sink at countertop elevation (revit 2013)
Wed, May 7, 2014 at 12:16:09 PM
Page generation time: 0.1359
