Forums >> Revit Building >> Technical Support >> Grid Bubbles relative to scope box.
Tue, Jul 10, 2007 at 11:12:28 AM | Grid Bubbles relative to scope box.
JoeATSHoP
How do I control exactly how the grid bubbles are associated to the scope box. Currently if I associate a grid to the scope box the bubble is located exterior to the scope box. I want exact control where I can have it offset a certain distance inside the scope box. Is there a way to do this?
-Joe
Tue, Jul 10, 2007 at 12:11:10 PM | Grid Bubbles relative to scope box.
rkitect
rkitect Avatar
4 Stars: 29 Votes
If I'm reading the question correctly (not really familiar with Scope Boxes), shouldn't you just be able to drag the end of the grid to where you want it to be?
Tue, Jul 10, 2007 at 12:20:42 PM | Grid Bubbles relative to scope box.
JoeATSHoP
I'm not looking for a work around. I have 32 floors and want consistancy.
-Joe
Tue, Jul 10, 2007 at 4:20:50 PM | Grid Bubbles relative to scope box.
rkitect
rkitect Avatar
4 Stars: 29 Votes
I don't think this is a workaround.  This is how you move the grid bubble's position.  The ends of the grids should lock into place and you should then be able to move the 3D (meaning it effects the grid in all views) location by clicking the little "3D" icon to move them all at once.  If that doesn't work (and this would be a workaround), you can create a reference plane that goes through all 32 floors and snap the ends of the grid to that.
Make Scope Box Visible after all Views Hidden
Tue, Oct 25, 2016 at 4:40:46 PM
Grid Line Visibility and Scope Boxes
Thu, Dec 7, 2006 at 2:59:44 AM
grids VS scope box
Thu, Sep 8, 2011 at 11:52:30 AM
Scope Box Datum Control
Fri, Apr 21, 2006 at 6:57:15 PM
Scope box not visible
Thu, Oct 19, 2017 at 12:33:04 PM
Page generation time: 0.1776
