Forums >> Community >> Newbies >> Is Revit able to do serious quantity surveying stuffs?
Wed, Jan 19, 2005 at 8:26:43 PM | Is Revit able to do serious quantity surveying stuffs?
ale02
ale02 Avatar
3 Stars: 3 Votes
Hi, everybody.. I got a few quick questions.. Just wondering is there anybody using revit's schedule for serious quantity surveying stuffs? Any pitfalls? No too sure about the accuracy of Revit's Quantity especially the pre-set areas and volume (e.g. for wall, floor & structures) and is there any way to counter-check or to know how Revit is programmed for those calculation? Open for discussion!
Life is never easy but nor it should be complex. Just stay simple Smile
Wed, Jan 19, 2005 at 8:44:16 PM | RE: Is Revit able to do serious quantity surveying stuffs?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Its defintely feasible however i've never had the need myself so I haven't delved into investigating it. Remember early versions of revit did include quantity surveying software... You are correct with the areas, i have found issues with incorrect (to a degree) reporting of areas... But i know there are people out there using it for this very purpose...
Thu, Jan 20, 2005 at 12:03:33 AM | RE: Is Revit able to do serious quantity surveying stuffs?
ale02
ale02 Avatar
3 Stars: 3 Votes
Thanks for your reply, Mr. Spot. Besides Area, I found that volume report sometime give some problems too. If you try to create a few simple structural family with extrusion (with solid and solid with void) and try the built-in volume report, it failed as it only recognized the full solid volumein both cases!? Of course to some extents, we can use formulas to work out the actual volume extraction but this post question is how reliable the quantity reporting espcially those built-in pre-programmed one?!
Revit 2009 - Quantity Take offs
Thu, Sep 9, 2010 at 4:41:22 PM
keynote text in schedule
Tue, Nov 1, 2011 at 9:34:37 AM
quantity of balusters
Tue, Nov 10, 2009 at 7:34:45 AM
rebar reinforcement quantity take off
Mon, Apr 5, 2010 at 4:55:25 PM
quantity of colums
Mon, Nov 23, 2009 at 2:36:32 AM
Page generation time: 2.3101
