Forums >> Revit Building >> Technical Support >> Odd error message
Tue, Jul 10, 2007 at 9:15:25 AM | Odd error message
courthouse
I have a saved file that I'm trying to open and keep getting an error message that the file is "past its end".  What does this mean and is there anyway to remedy whatever problem is causing this message.
It is a file from a project that hasn't been opened in several months but I've never had this problem with older files or files saved in older versions of the software...
Tue, Jul 10, 2007 at 12:21:06 PM | Odd error message
sdbrown
5 Stars: 3 Votes
Thats a bad error which means that during the copy process somehow windows didnt' copy all the data. you can try sending it to support but its probably a dead file and you'll need to find a back upp.
Tue, Jul 10, 2007 at 12:53:09 PM | Odd error message
courthouse
That's what I was expecting, but hoping otherwise....
Thanks for the help
Wed, Jul 11, 2007 at 9:51:49 AM | Odd error message
Elmo
3.5 Stars: 4 Votes
I've seen this message a few times in the last few months. I'm starting to suspect that it is a network based problem. Whenever it's a slow network or network spike it seems to corrupt the file. It doesn't seem to do this to workset files, only normal project files.
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:33 AM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:48 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016
Tue, Oct 4, 2016 at 9:09:33 AM
Keynotes Error Message
Mon, Jan 24, 2011 at 9:12:17 AM
Error Message
Fri, Feb 18, 2011 at 2:24:25 PM
Page generation time: 0.1295
