Forums >> Revit Building >> Technical Support >> Keyboard Shortcuts
Wed, Jan 19, 2005 at 7:56:08 PM | Keyboard Shortcuts
Birdman
I have modified my keyboard shortcuts for Revit 7 and have found a couple of problems: 1. Single character shortcuts do not seem to work (even though the example given shows single a character) 2. I can not create a shortcut to draw an arc, it seems the closest I can get is to use the line shortcut and then select an arc (so what's the point of the shortcut?).
Wed, Jan 19, 2005 at 8:39:06 PM | RE: Keyboard Shortcuts
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. Revit bases its shortcut system on 2 letter codes. You can use single letter, however you will need to hit enter after the letter to select the tool. 2. The shortcuts are used only to select tools without having to browse menus, they cannot be used to select specific features of a tool.
Thu, Jan 20, 2005 at 11:03:15 AM | RE: Keyboard Shortcuts
Team RPM
#2 bugs me on a daily basis, especially when I'm doing alot of switching between AutoCAD on one screen and Revit on the other. Somethingelse I'm sure you'll find 'entertaining' is the keyboard shortcuts you created don't work in the family editor and there is no way access these to modify them. *grrr*
Thu, Jan 20, 2005 at 5:15:30 PM | RE: Keyboard Shortcuts
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Certain keyboard shortcuts are available in the family editor, but yes some aren't. For instance. TX and RP for text and reference plane work fine... CO for component doesn't???
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
Keyboard shortcuts
Thu, Jul 3, 2008 at 11:14:44 AM
Keyboard Shortcuts Won't Open/Show
Tue, Feb 26, 2013 at 11:09:04 AM
Keyboard Shortcuts??????
Thu, Jun 12, 2008 at 9:19:18 AM
Looking for a few handy keyboard shortcuts
Mon, Sep 27, 2010 at 8:21:51 PM
Page generation time: 0.4223
