Forums >> Revit Building >> Technical Support >> green walls?
Mon, Jul 9, 2007 at 4:02:36 PM | green walls?
aranttila
anyone have ideas on drawing vertical creeper plants like ivy or other vines?  i'm drawing a green wall and i've been trying to modify existing revit shrubs using the ground cover family, but i'm not able to make them vertical.  any help would be very much appreciated.  thanks!
Tue, Jul 10, 2007 at 12:16:17 PM | green walls?
sdbrown
5 Stars: 3 Votes
I create a curtain panel for the green screen with a crosshatch pattern set to the spacing and transparent. then I'd create a generic family that is just some linework or a dwg of the ivy pattern you want, nest that into your panel family and place as needed. Or just place the ivy in the model from the family you create. Model lines work very well for this kind of organic thing.
James Hardies Revit content walls are green?
Fri, Jul 10, 2015 at 5:17:00 PM
How to make a Green Roof
Fri, Feb 1, 2013 at 11:28:34 AM
Pool Water Green in Rendering
Thu, Feb 16, 2012 at 1:17:13 PM
Green roofs
Thu, Jul 12, 2012 at 4:59:42 PM
UNDERSTANDING space and space tags - Green coloring
Fri, Jan 27, 2012 at 11:25:13 AM
Page generation time: 0.2927
