Forums >> Revit Building >> Technical Support >> dumb waiter?
Mon, Jul 9, 2007 at 3:42:44 PM | dumb waiter?
Thread Post Kudo! #1
ledge
looking for a dumb waiter component or at if there is a way to change an elevator into one?
Tue, Jul 10, 2007 at 12:48:02 PM | dumb waiter?
rkitect
rkitect Avatar
4 Stars: 29 Votes
If you want to just change an elevator family into a Dumb Waiter, you can open the elevator file and reduce the size of the elevator to the size of the dumb waiter.  Then you would want to make the doors small enough to match the size of the dumb waiter doors.  Did you have a specific model or size in mind?
Tue, Jul 10, 2007 at 12:59:22 PM | dumb waiter?
ledge
I pulled the specs for a restaurant dumb waiter off the Butler Buddy website i.e. www.butlerbuddy.com
Tue, Jul 10, 2007 at 4:30:13 PM | dumb waiter?
rkitect
rkitect Avatar
4 Stars: 29 Votes
Butlerbuddy.com is an advertising website.  Did you mean ButlersBuddy.com by chance?
 I jury rigged this together.  Not much there in terms of 3D or section view, but it should work in plan view for now.  You'll need to place one at each level and cut a shaft in the floor.
dumb waiter?
Mon, Jul 9, 2007 at 3:37:08 PM
Probably a dumb question but...........................
Mon, Jul 23, 2007 at 11:31:51 AM
dumb question
Tue, Nov 13, 2007 at 1:34:04 AM
(Dumb question) Can't see first floor when in second floor view [Revit 2015]
Thu, Jul 16, 2015 at 2:23:26 PM
Dumb Callouts in Revit
Fri, Aug 26, 2011 at 12:45:45 PM
Page generation time: 2.5094
