Forums >> Revit Building >> Technical Support >> Ground Floor info. appearing on Second Floor
Mon, Jul 9, 2007 at 1:41:00 PM | Ground Floor info. appearing on Second Floor
Silva
My second floor plan is showing walls and doors from the First Floor in grey.  I've checked the view range and the 'Bottom' indicates Second Floor.  I can't seem to figure out what's causing the ground floor info to show through?  My Third floor is set up the same way, 'Bottom' is set to Third Floor, and it appears perfectly (no info from below showing through.)
Appreciate any feedback!!
Silva the Newbie.
Mon, Jul 9, 2007 at 3:11:08 PM | Ground Floor info. appearing on Second Floor
Have you got the ground floor on as an underlay?  Check vp.
Mon, Jul 9, 2007 at 3:17:41 PM | Ground Floor info. appearing on Second Floor
Silva
Hmm.. I must have.  I just set underlay to None and it's gone... GREAT! THANKS!
Mon, Jul 9, 2007 at 3:34:27 PM | Ground Floor info. appearing on Second Floor
Silva
Thu, Jun 9, 2016 at 12:34:00 PM | Ground Floor info. appearing on Second Floor
BriDS
I'm having the same problem.  What's VP?
Thu, Jun 9, 2016 at 2:10:53 PM | Ground Floor info. appearing on Second Floor
marmiketin1
4.5 Stars: 10 Votes
VP is probably View Properties. not too sure tho. If you can see elements from the floor below first make sure there is no underlay on. If it is still showing with no underlay set then check Visibility Graphics and make sure floors are turned on and your view range is set properly for your view.
Thu, Jun 9, 2016 at 2:24:40 PM | Ground Floor info. appearing on Second Floor
BriDS
Yeah, it's properties!  It just doesn't say View Properties so I was thrown off by the V.  Newby here, I don't know the lingo yet.
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:10 AM
Faint lines showing from ground floor on first floor
Sat, Mar 10, 2012 at 4:40:33 PM
how to see through floor cut opening on plans?
Thu, Nov 18, 2010 at 10:02:14 PM
how to see upper levels dash lines at the ground floor?
Thu, Dec 24, 2009 at 2:26:32 AM
Page generation time: 0.4217
