13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> INTERIOR RENDERING
i saved the worst for last: interior rendering with no sun.. all i know is when you throw a camera in a room and render it all you get is MAYBE some light seeping in from a window.. i need a tutorial on interior light rendering.. i mean starting with no lights no nothing.. like how do you put ceiling lights in and make them work for rendering.. anything other than revit help.. thank you
Well, if you just want light, you can always put in the good ol' 'Studio Light' from the library that ships with Revit. This is a global. I found that most of the lights that ship with Revit leave jagged lines even under the highest render settings. This is usually because of the modeling of the housing around the light source. I haven't done much modeling with light housings so I'm not sure what works best. As far as adding ceiling lights, it's as simple as adding any component. If the light family is ceiling based, then you'll need a ceiling object to host it (durr). There are some recessed can lighting families that ship that will at least get you started Hope this gets you started. Best of luck!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
first of all your ceiling lights have to come in in the ceiling views, to get a feel for it I would start with some recessed can lights and you could also experiment with studio lights, in your rendering tab when you set up the scene got to settings and set it to be an interior light rendering, then go to your lighting settings in the settings dialog box and un check the sun as one of your light sources and that way you get the sun out of your radiosity calculation I hope this helps
Just wanted to note that the ceilling lights can be place in ANY view, but it is easiest to place them correctly in a RCP view. Also be sure you do actually run a Radiosity before you Raytrace. This will add the more photorealistic touches to the rendering.
Interior Rendering |
Tue, Aug 9, 2011 at 10:33:14 AM
Revit 2009 interior rendering isue [ 1 2 ] |
Wed, Sep 3, 2008 at 4:29:43 PM
23
Interior Rendering Problem [ 1 2 ] |
Tue, Jun 7, 2011 at 1:17:37 PM
17
Exterior night rendering with interior lights on? R16 |
Wed, Aug 3, 2016 at 1:23:36 PM
Interior Rendering is very Dark |
Tue, Apr 30, 2013 at 2:30:55 PM
