Forums >> Revit Building >> Technical Support >> revit 2008 - error loading family into project
Fri, Jul 6, 2007 at 11:52:31 AM | revit 2008 - error loading family into project
archshanna
I'm trying to load this family I just downloaded from this website into my project and it gives me this error message: Can't make type "Lav 2-Station : Lav - Educational - 2-Station".  Is there a way to fix this problem?  I need this sink!  Smile
Mon, Jul 9, 2007 at 9:12:47 AM | revit 2008 - error loading family into project
rkitect
rkitect Avatar
4 Stars: 29 Votes
Sounds like there is a constraint problem with the family.  You may need to open the family and check the constraints.  Try removing all constraints while in the family editor and then re-hosting the family.  If it is a wall based family, my guess would be that something doesn't work with the width of the wall you are trying to host the family on (IE: The family was not made to flex... bad family creator.. BAD! Puh).
HTH
A fatal error loading family into project overwriting existing
Mon, Jun 22, 2015 at 8:03:38 AM
Error Loading Profile Family
Sun, Nov 21, 2010 at 12:31:22 PM
Casework not loading into project
Thu, Aug 15, 2013 at 7:36:39 AM
How to fixed error when uploading family to project rvt. file
Tue, Jun 19, 2012 at 4:16:04 PM
error when loading components
Wed, Dec 1, 2010 at 2:33:54 PM
Page generation time: 2.1108
