17 Users Online (15 Members):
Forums >> General Discussion >> Revit Project Management >> Color and surface in rendering remain grey
3 Posts No Rating |
When I burn a rendering, my walls remain grey and the surface texture does not show after the rendering is complete. It all stays in default grey. Please help.
Check under your Settings tab, in Option. Go to the Rendering tab, and check to make sure that the Rendering Materials Directory is pathed correctly. If you are working over a network and your materials are on the server you will want to be sure that the these directories are pointing to the correct drive. I'm not certain that this will fix the problem, but it is what I would check first. Good Luck
----------------------------------- ArchWestCY |
rendering issue |
Mon, May 21, 2007 at 11:27:43 PM
why shading material color gets overridden by surface color |
Wed, Apr 25, 2018 at 9:53:40 AM
massss painting |
Tue, Mar 20, 2012 at 10:32:14 PM
Rendering Help..! showing up grey |
Fri, May 8, 2015 at 1:02:28 PM
any trick in Revit rendering not make it so grey? [ 1 2 ] |
Wed, Jan 5, 2011 at 3:09:06 PM
22
