Forums >> Revit Building >> Technical Support >> Dashed roof ouline in plan view
Tue, Jan 18, 2005 at 8:07:13 PM | Dashed roof ouline in plan view
riksta
ADT automatically displays the ouline of the roof over the floor plan in 'top' view, does any one know how to display a dashed outline of the roof in plan view in Revit? (not including fascias or gutters etc)
Tue, Jan 18, 2005 at 9:02:55 PM | RE: Dashed roof ouline in plan view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the floor plan, underlay the level that the roof is on. You should see the roof now in a light grey line. Now use the linework tool, set it to dashed or overhead, then click on each of the edges you wish to show on the floor plan. To select all at once hover over the edge and click tab... You can now turn the underlay off and the linework remains. Its also linked with the roof so if your roof changes so will the linework (to an extent, depends how drastically you change the roof). HTH.
Tue, Jan 18, 2005 at 9:39:33 PM | RE: Dashed roof ouline in plan view
riksta
Spotty as usual you have come through with the goods. You are are THE Revit guru. Thanks heaps!!
Wed, Jan 19, 2005 at 5:57:01 AM | RE: Dashed roof ouline in plan view
Steve_Stafford
5 Stars: 2 Votes
This is a particularly good opportunity to overlay plan views on sheets. Make a copy of a roof plan view and turn off everthing but the roof. Then over-ride the line work for the roof object so it is using a dashed pattern (whatever you want really). Then drag this view over the floor plan on a sheet. It will snap into alignment over the floor plan as long as they are the same scale. Now any changes you make to your roof or additions you make will automatically show accordingly.
Tue, Sep 16, 2008 at 10:20:40 AM | Dashed roof ouline in plan view
Hart
Hart Avatar
I have been using this technique and find its an easy way to show the roof above. I am having a problem with the roof disappearing in plan (parts of it) usually I can go into the hidden view and unhide it for that piece. Not so this time it seams that the roof is in all my views and some of it in my plan, but part of it is missing. Its not showing up in the underlay either so, does anyone know what I did to screw it up? and how to fix it?
Sun, Oct 26, 2008 at 11:31:34 PM | Dashed roof ouline in plan view
latinoz
first day on the site and ive found an answer to a problem i got the other day..thanks for the question and answer!
objects above - dashed line
Fri, Oct 21, 2005 at 4:43:04 PM
Dashed lines in plan from window above
Mon, Oct 11, 2010 at 3:28:04 PM
How to show structure below dashed
Tue, Jan 10, 2006 at 9:27:02 PM
11
roof lines in floor plan view...i need them darker..how?
Tue, May 5, 2009 at 3:21:01 AM
How do I get to show lines dashed in plan view?
Sat, Oct 24, 2015 at 4:57:45 AM
Page generation time: 3.3395
