Forums >> Revit Building >> Technical Support >> Foundation visibility in Elevations
Mon, Jul 2, 2007 at 12:02:46 PM | Foundation visibility in Elevations
christinea
I'm working on a simple Revit project, but can figure out how to have my elevation hide every thing under the grade line.....
thanks
Mon, Jul 2, 2007 at 3:12:43 PM | Foundation visibility in Elevations
MrBob
3 Stars: 2 Votes
I make a workset just for the foundation walls and then shut off the workset in the vv.  On another project, I used the linework tool to show the lines as hidden.  HTH
Tue, Jul 10, 2007 at 2:06:45 PM | Foundation visibility in Elevations
JayDee08
Have you tried creating a topo surface?
If not, try the following:
Create a "ground" level; add a toposurface at that ground level (lets say, approx the size of your lot) and a pad at (or under) basement slab level; make sure your elevation line is within your toposurface edges and it should do it.
Tue, Jul 10, 2007 at 2:37:23 PM | Foundation visibility in Elevations
christinea
My problem was that my elevation marker wasnt in the correct location.
Thanks for the help.
Christine
Spot Elevations
Thu, Oct 5, 2006 at 3:29:16 PM
Elevations and Line Styles
Thu, Dec 9, 2004 at 5:40:28 PM
Foundation Visibility
Wed, Mar 25, 2009 at 1:43:48 AM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Strip Footing not wanted in Foundation schedule
Mon, Mar 28, 2016 at 4:05:52 PM
Page generation time: 0.1993
