Forums >> Revit Building >> Technical Support >> Data in file Corrupt
Sun, Jul 1, 2007 at 9:30:19 PM | Data in file Corrupt
sharris2909
Any thoughts or suggestions on recovering this file:
 Error message reads " Data in file is corrupt and needs to be manually recovered."
Sun, Jul 1, 2007 at 10:54:05 PM | Data in file Corrupt
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only Autodesk can do a manual recovery of a file AFAIK.  Send the file to Autodesk Product Support via subscription centre.
Regards,
Chris.
Fri, Sep 21, 2012 at 4:35:43 PM | Data in file Corrupt
Socha
PUEDE QUE TU DISCO C: ESTE LLENO, BORRA UN POCO DE INFORMACION Y LISTO! ME ACABA DE PASAR ESO.
LOOK AT THIS:
https://www.facebook.com/note.php?note_id=10150302003283186
Mon, Sep 24, 2012 at 9:55:15 AM | Data in file Corrupt
jlights
3 Stars: 2 Votes
I work in a large company and we see this from time to time. Believe it or not, syncing with central usually clears it up and the file is not really corrupt. Which of course is no guarantee that YOUR file is not corrupt- just that this alarming message is, at least for us, usually a case of Revit crying wolf. Try reopening the file with the Audit box checked, then sync with central, and see if that helps.
jlights
Wed, Jul 2, 2014 at 10:24:34 AM | Data in file Corrupt
seanpmurphydesign
This happened to me recently and here was my solution after trying everything else.
Open a new project -> Go to restore backup -> Pick the backup file of the central model you are trying to recover -> Save As a new central model -> Open and save without worksets.
Try multiple backup times to get before and rid yourself of the corruption.
It's not perfect but I only lost several hours on the project vs. 3 days since my last detached central. It also beats waiting several days for Autodesk Support to fix it for you.
Edited on: Wed, Jul 2, 2014 at 10:25:00 AM
corrupt file recovery
Wed, May 7, 2008 at 6:50:35 PM
Data Corrupt and Needs to Be Manually Recovered-- but no real problems
Tue, Apr 27, 2010 at 9:11:07 AM
Element's internal join data is corrupt
Mon, Jan 10, 2022 at 12:37:58 PM
Manually Recovering Corrupt Files
Tue, Jun 28, 2016 at 6:55:36 AM
CORRUPT FILE??!!**
Tue, Jun 24, 2008 at 12:43:36 PM
Page generation time: 2.0207
