Forums >> Revit Building >> Technical Support >> No Crop Region is greyed out??
Sat, Jun 30, 2007 at 11:26:48 AM | No Crop Region is greyed out??
DaveF
Hi
I'm sure this is basic, but i can't work out why in the section I've just created, the No crop region option is greyed out. The other two option work fine.
What am I doing wrong?
Fri, Jul 13, 2007 at 9:23:10 AM | No Crop Region is greyed out??
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
A crop region is required in a section view. If it is an issue with visibility of the crop region boundary you can right click on the crop region boundary and select "Hide Annotation In View"
Elevation Tags Greyed out and crop region
Mon, Aug 2, 2010 at 12:42:14 PM
Copy Crop Region (2011)
Wed, Nov 17, 2010 at 10:44:37 AM
Revit Text Element Appearing Outside Crop Region
Fri, Nov 22, 2013 at 7:37:04 AM
12
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:07 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:29 PM
Page generation time: 0.1455
