Forums >> Revit Building >> Technical Support >> TILTED curtain walls
Sat, Jun 30, 2007 at 5:55:48 AM | TILTED curtain walls
amaruna
1 Stars: 3 Votes
hi, I'm dealing with a problem right now.I'm trying to build a curtain wall that is tilted .In order to benefit from the mullion command I want to do it using the curtain wall command  but I haven't discovered till now how to do it. Otherwise I can use the "create mass" command but that would mean that I have to manually create each mullion and also the doors and I need to finish the model as soon as posible.
Any advice is wellcome.
Sat, Jun 30, 2007 at 10:08:50 AM | TILTED curtain walls
sdbrown
5 Stars: 3 Votes
2 ways,  1 use the ruled curtain system now called curtain system by line I think..  Basically you just set a level for the bot. of the wall and one for the top, then draw a line where you want the bottom , and a line where you want the top, then these define the top and bot location of the curtain wall.
Create a sloped mass, then use the curtain system by face. set the curtain system to have the mullion pattern you want.
Sun, Jul 1, 2007 at 4:26:50 AM | TILTED curtain walls
amaruna
1 Stars: 3 Votes
thank you so much for the advice.I tryed both ways but i think that the option "curtain system by lines"it's rather difficult to control.The best result that I reached was using the mass control  and then the "curtain system by faces ".thanx again
How to make a tilted roof
Mon, Mar 14, 2011 at 3:36:00 PM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
tilted walls
Mon, May 16, 2005 at 2:04:18 PM
tilted, slanted or tapered walls
Wed, Dec 3, 2014 at 7:32:27 AM
Page generation time: 0.8549
